Old 03-22-2012, 09:11 AM
hotshotiguana hotshotiguana is offline
Create an arc between two points
I have two x, z points - for example ([1.722, .46], [3.94, .026]) - and I am trying to draw an arc (or a great (or small) circle) between the two points. I also have calculated 50 control x, z points between the points if this is beneficial to the solution.
Currently, I am using viz.LINE_STRIP to create about 50 line segments between the two points and it doesn't look at all.
Any help would be great and please let me know if more information is needed.
Chris
Old 03-22-2012, 10:11 AM
What exactly is wrong with your current solution? Is the arc not smooth enough? If so, you will just need to create more control points.
Old 03-22-2012, 10:44 AM
I am not calculating the y-values correctly. When drawn, it looks like a staircase between the two points.
Old 03-22-2012, 10:56 AM
Can you post some sample code?
Old 03-22-2012, 11:28 AM
So I transferred some Matlab code into Python and then did a 3D plot, see below code.
import numpy as np
from mpl_toolkits.mplot3d import Axes3D
import matplotlib.pyplot as plt
def get_sphere_line(center, pt_1, pt_2):
Get the coordinates to craft an arc
x0, y0, z0 = center
x1, y1, z1 = pt_1
x2, y2, z2 = pt_2
v1 = [x1 - x0, y1 - y0, z1 - z0] # Vector from center to 1st point
r = np.linalg.norm(v1) # The radius
v2 = [x2 - x0, y2 - y0, z2 - z0] # Vector from center to 2nd point
v3 = np.cross(np.cross(v1, v2), v1) # v3 lies in plane of v1 & v2 and is orthog. to v1
v3 = r*v3/np.linalg.norm(v3) # Make v3 of length r
# Let t range through the inner angle between v1 and v2
t = np.linspace(0, np.arctan2(np.linalg.norm(np.cross(v1, v2)), np.dot(v1, v2)), num=100)[:, np.newaxis].T
v = np.array(v1)[:, np.newaxis]*np.cos(t) + np.array(v3)[:, np.newaxis]*np.sin(t) # v traces great circle path, relative to center
xs, ys, zs = v[0, :] + x0, v[1, :] + y0, v[2, :] + z0
return xs, ys, zs
xs, ys, zs = get_sphere_line([2.85, 0.001, 0.238], [1.722, .001, .46], [3.94, 0.001, 0.026])
fig = plt.figure()
ax = fig.add_subplot(111, projection='3d')
ax.plot(xs, ys, zs)
plt.show()
The below code is how I am trying to implement it in Vizard, but it isn't working properly.
vs = get_sphere_line([2.85, 0.001, 0.238], [1.722, .001, .46], [3.94, .001, 0.026])
viz.startLayer(viz.LINE_STRIP)
viz.lineWidth(5)
viz.vertexColor(viz.YELLOW)
for v in vs:
viz.vertex([v[0], v[1], v[2]])
viz.endLayer()
Old 03-22-2012, 12:07 PM
I found the problem, here is my solution in Vizard:
xs, ys, zs = get_sphere_line([2.85, -1., 0.238], [1.722, .001, .46],
viz.lineWidth(5)
viz.pointSize(5)
for pos in zip(xs, ys, zs):
viz.vertex([pos[0], pos[1], pos[2]])
points = viz.endLayer()
arc, great circle, vizshape
Why I need two points for viz.startlayer(viz.POINTS) jincheker Vizard 1 01-28-2011 09:46 AM
avatar walking over a sequence of points IGoudt Vizard 1 10-16-2009 12:22 PM
Create Button or Text Chrissy2009 Vizard 1 07-15-2009 06:34 PM
Draw Line between Points Chrissy2009 Vizard 2 05-13-2009 05:42 AM
How to create a sky? guxmy01 Vizard 1 05-28-2008 01:07 PM
