Old 07-30-2014, 12:49 PM
lawry2 lawry2 is offline
Newbie - Trouble using loops
Hi all,
I'm new to using Vizard and am having difficulty using loops. My issue is that when I use a loop, it blocks the environment from being rendered. I thought that this was OK as I was using the same method I saw in the Vizard documentation.
import viztask
env = viz.add('../models/environment.OSGB')
def run():
	while True:
                # Something simple
		print viz.MainView.getPosition()
		print viz.MainView.getEuler()
viztask.schedule(run())
What I get here is just a black window. The model is never seen but the output window shows the camera Euler and position. I'm aware that the loop is blocking but how do I get around this?
Old 07-30-2014, 02:35 PM
Functions scheduled with viztask must contain a yield command. The following should work:
import viztask
env = viz.add('dojo.osgb')
def run():
	while True:
		# Something simple
		yield viztask.waitTime(1)
Old 07-30-2014, 02:38 PM
Thanks for the quick reply.
Yep, that worked. I must ask though, why is this?
Using what you said, I have put the print statements in another function and I call that using a yield statement.
Old 07-30-2014, 02:51 PM
Vizard's task functions are implemented using Python generators which use yield statements.
trouble tracking multiple lights Vkathrynr Precision Position Tracker (PPT) 2 08-26-2009 01:07 PM
Trouble transitioning from one vizard DBurks2818 Vizard 3 04-28-2009 03:46 PM
Collision trouble digitaldarklord Vizard 6 09-16-2008 05:04 PM
Trouble Exporting to .ive le perdusier Vizard 2 11-27-2007 05:31 PM
trouble with winviz.exe bnord Vizard 4 09-21-2006 05:22 AM
