Old 04-26-2009, 07:19 PM
DBurks2818 DBurks2818 is offline
Trouble transitioning from one vizard
...file to another.
Hey all,
I'm having a lot of trouble getting one vizard file to transition to another by way of a button. I was able to get it to work once, but now it will no longer work upon creating a new button and giving it the same functionality. I'm also putting all of this within a different scene from the main one, if that helps.
viz.clearcolor(0,0,1)
Next = viz.addButton()
def onButton(obj,state):
    if obj == Prev:
        if state == viz.DOWN:
         vizact.onbuttondown(Next, execfile('Vizard1.py'))
         Prev.remove()
         MainMenu.remove()
         Nxt.remove()
         Tutorial.remove()
         Previous.remove()
         MainBtn.remove()
         Next.remove()
viz.callback(viz.BUTTON_EVENT,onButton)
And 'Vizard1.py'...
building = viz.add('level1.3ds')
building.setPosition( 0, 0, 10)
building.setScale( 7.5, 7.5, 7.5 )
Why won't this work with the button I've created? Is there another/more efficient way to do this without just putting all of the code in one file and putting the entire destination file into the source file and using scenes?
It would be nice if someone could help me figure this out by Friday, as it's urgent.
Thanks for any help provided.
Old 04-26-2009, 07:50 PM
Here's my code if it helps (Main file is "GUINewTitle"):
http://rapidshare.de/files/46918311/Linking.rar.html
The button is on the new game screen, "Next."
Old 04-26-2009, 08:28 PM
Ok, it seems that the problem is that Vizard isn't able to handle the amount of buttons/data in my main file while still being able to load the .3ds file. Is there anyway around this?
Old 04-28-2009, 02:46 PM
Why are you trying to open up different Vizard windows? Can't you do this with one Vizard window and multiple scenes?
McAfee Privacy Service 8.1 causes Vizard not to run mspusch Vizard 2 09-24-2008 05:17 PM
new vizard user having trouble bhs125 Vizard 1 09-10-2004 02:01 PM
