Old 09-03-2008, 01:31 AM
digitaldarklord digitaldarklord is offline
Send a message via MSN to digitaldarklord Send a message via Skype™ to digitaldarklord
Collision trouble
Greetings
I have trouble with viz.MainView.collision( viz.ON ) in combination with shaders
This works with the standard skydome.
But...
If I add another sky routine see the code snippet below
Yes and I know how to turn it on ;-)
# sky old style
env = viz.add(viz.ENVIRONMENT_MAP,'sky.jpg')
sky = viz.add('skydome.dlc')
sky.texture(env)
sky.disable(0x3000) #Disable clip plane on sky
# new style
#Add sky model
#sky = viz.add('sky.osg')
#Add textures
#horizon_tex = viz.add('horizon.png')
#horizon_tex.wrap(viz.WRAP_S,viz.CLAMP_TO_EDGE)
#horizon_tex.wrap(viz.WRAP_T,viz.CLAMP_TO_EDGE)
#cloud_tex = viz.add('clouds.png')
#cloud_tex.wrap(viz.WRAP_S,viz.REPEAT)
#cloud_tex.wrap(viz.WRAP_T,viz.REPEAT)
#Apply textures to sky
#sky.texture(horizon_tex,'',0)
#sky.texture(cloud_tex,'',1)
#Add shaders
#sky_vp = viz.add('sky.vp')
#sky_fp = viz.add('sky.fp')
#Apply shaders to sky
#sky.apply(sky_vp)
#sky.apply(sky_fp)
#viz.clearcolor(viz.GRAY)
#viz.fov(70,1.3)
#sky.translate(0,-400,0)
#CLOUD_SPEED = 1.0
When calling this routine is messes up the collision detection. I changed nothing added only the routine above called it from the timer so I am lost
Part 2 of this question.
In my app I created a helicopter flying a maze with a searchlight. So I added a nightmode with affect and uneffect. If you are in the light bundle the sky lights up also with this shader. bizar...
See the screenshots what I mean with this
ID:	266   Click image for larger version
ID:	267   Click image for larger version
Old 09-05-2008, 09:04 PM
Thanks for the post. Sorry we have not been able to give you an answer yet. We have had a busy few days but we we will try to respond early next week.
Old 09-08-2008, 06:16 PM
Sorry, I am not quite clear on your question. When you say that collision detection is messed up what exactly is happening.
Old 09-12-2008, 12:43 PM
Your intersection tests might be conflicting with the sky model. Try disabling intersections tests on the sky using the following code:
sky.disable(viz.INTERSECTION)
Old 09-15-2008, 06:46 AM
To define it more clearly. When I use the code as posted here# the collsion is not working or something. When we use this code to generate nice moving clouds etc. The user is able to walk trough objects. (about a meter or so. If I use the more simple skydome code. The collision works normal. So my conclusion it has to do with the code as posted. Because I did not change anything else
Old 09-15-2008, 06:50 AM
Second part question
When I create a search light on the helicopter and let it travel in the room in the xyz grid. I see something strange happening. The light also lights up the skydome.
I do not understand it because I created the unaffect on in
sky.unaffect
Old 09-16-2008, 05:04 PM
Is it possible for me to view the complete code and load up this world here. You can email me at loomis@worldviz.com and I can give you directions for uploading.
Collision detection with haptic pen mjabon Vizard 3 01-17-2008 07:35 PM
linked object collision pgagolf Vizard 1 04-19-2007 02:27 PM
Collision with avatars and scene not working JvdBosch Vizard 12 09-14-2006 07:01 PM
collision events trigger Eunice Vizard 1 01-03-2006 11:39 AM
Walking avatars --> collision detection? sjroorda Vizard 3 10-13-2005 05:47 AM
