Old 10-09-2009, 12:28 AM
atamasan atamasan is offline
Question about collision for Hand model(bones)
Hello.
I'm using Hand model with patriot(Polhemus).
I have tried some methods for hand model collision because I want the hand model to grab object.
But when I try to apply collision, I get error messages every time.
My method is like this....
hand=viz.add('hand.cfg')
(get bones :bone01~bone16)
bone01=hand.getBone('bone index 1-2')
bone16=....
bone01.collideMesh()
bone16=...
Then, I run the code and errors always appear. But I can hardly understand errors written in English.
Please give me ideas about that.
Thank you for reading.
Old 10-18-2009, 08:42 PM
I have solved the problem by myself.
Thank you.
But I've got another question.
When I use <node3d>.collideSphere, the command usually work great. But when I change the scale of the node(especially, when I make the node small), collideSphere doesn't work.
For example,,,
ground=viz.add('shpere_ground3.ive')
ball=viz.add('white_ball.wrl')
ball.setScale(.1,.1,.1)
ball.setPosition(0,.5,0)
ball.collideSphere()
In this case, collision doesn't happen(ball falls down through ground). But if I change the scale of the ball(I make the ball bigger like [2,2,2]), collision can be seen.
What is the reason for this? Please give me some advice.
Old 10-23-2009, 11:53 AM
Vizard uses the ODE physics engine and we have noticed that it has problems computing collisions for very small objects. I would suggest avoiding using small scales on physics objects if possible.
Old 10-26-2009, 05:50 AM
Hi, thank you for your advice.
Fortunately, to avoid using small scales is not big problem for me.
I will try with big scaled objects.
Thank you very much.
Collision detection with specific models just alex Vizard 1 02-06-2009 12:02 PM
Collision with child nodes rubberpimple Vizard 4 09-17-2008 05:27 PM
Collision detection with haptic pen mjabon Vizard 3 01-17-2008 07:35 PM
General question and question regarding arrays dan12345 Vizard 1 01-15-2008 11:15 AM
Walking avatars --> collision detection? sjroorda Vizard 3 10-13-2005 05:47 AM
