Old 07-14-2015, 01:11 PM
gerardo697 gerardo697 is offline
Adding Images to Objects
I was wondering if there is a better approach when trying to add an image onto a wall. I have created the following quadrilateral, and when I run the program it just shows a brown square. How can I fix this?
viz.setMultiSample(8)
viz.fov(60)
viz.startLayer(viz.QUADS)
viz.vertex(0,0,15)
viz.vertex(10,0,15)
viz.vertex(10,10,15)
viz.vertex(0,10,15)
myQuad = viz.endLayer()
texture = viz.add( 'duck.jpg' )
myQuad.texture( texture)
Old 07-17-2015, 06:27 AM
One way to do this
I found out that the following works with any kind of picture extension.
pic = viz.addTexture( '20150716_113030.jpg' )
quad = viz.addTexQuad()
quad.setPosition([x,z,y])
quad.setSize([width,height])
quad.setEuler([270,0,0])
quad.texture(pic)
The setEuler() part is if you want to turn the picture around.
Adding objects bobbin_93 Vizard 1 07-16-2014 05:15 PM
Adding Objects to all Scenes jassel41 Vizard 1 11-29-2010 02:35 AM
adding new objects gina Vizard 4 11-29-2006 11:01 AM
