Adding Objects to all Scenes
Is there a way to add an object to all scenes? What I want to do is set up a menu scenario which is appended to the screen but want it in every scene. For now, I have it set up where the code is duplicated for scene 1 and scene 2 and the objects are added to their respective scenes, but the objects are exactly the same and I need it for around 4 scenes. Is there a way to make it so an object gets added to every scene? Thank you, Jassel41 |
hi jassel41
Could you use the clone command to clone the menu objects to the other scenes. i dont know if this will work but might be worth a try. Thanks |
Similar Threads | ||||
static or dynamic objects | shahramy | Vizard | 2 | 11-10-2010 12:32 AM |
Semi-circle array containing target and distractor objects | ptjt255 | Vizard | 3 | 08-04-2009 03:09 AM |
Lightwave objects rotation problem | hosier | Vizard | 6 | 02-13-2009 12:04 PM |
adding new objects | gina | Vizard | 4 | 11-29-2006 11:01 AM |
Could not find plugin to load objects... | halley | Vizard | 1 | 05-30-2006 11:01 AM |
