Old 06-01-2015, 09:56 AM
vlc vlc is offline
Using VRPN and INtersense to Connect Computer A with Computer B
I have an IS-900 connected to Computer A and running Vizard. Computer B is not connected to IS-900 but does run Vizard. Is there a way (maybe through VRPN) that allows computer B to connect to the IS-900 which is connected to computer A?
Old 06-02-2015, 10:53 AM
Can you describe the setup and what you're trying to accomplish? You could send data from one Vizard app to another using a VRPN server or network commands but there will be added latency.
Old 06-02-2015, 11:00 AM
vlc vlc is offline
Hi Jeff,
Computer A has the IS900, however I want Computer B to be able to connect to the tracker on the IS900 using VRPN. I know that you mentioned in other posts how to create the stream, but my question is: how do you actually obtain the data from the stream. If Computer A has the VRPN stream running, how would I get that data from the stream using computer B. Does that make sense?
Old 06-02-2015, 02:49 PM
Here's an example using a keyboard tracker.
Server Code:
Press the wasd keys to move the tracker
import vizcam
import vizinfo
vizinfo.InfoPanel()
vrpn = viz.add('vrpn7.dle')
server = vrpn.addTrackerServer('VizardTracker')
tracker = vizcam.addKeyboardPos()
server.setTracker(tracker)
def printData():
	print tracker.getPosition()
vizact.onupdate(0,printData)
Client Code:
Press the wasd keys in the server window to
move the axes model here in the client
import vizshape
import vizinfo
vizinfo.InfoPanel()
viz.move([0,0,-6])
viz.addChild('sky_day.osgb')
axes = vizshape.addAxes()
tracker = vrpn.addTracker('VizardTracker@localhost')
viz.link(tracker,axes)
Old 06-03-2015, 01:44 PM
vlc vlc is offline
Thanks a lot, Jeff. Was able to make it work through a wired connection. Do you happen to know if I could try doing this via wireless connection? I tried doing it with the IP Address but that doesn't seem to help. I tried doing @IPADDRESS instead of @hostname.
Old 06-05-2015, 03:33 PM
VRPN data can be sent over a wireless connection. The code should be the same for either a wired or wireless setup.
intersense, vizard 4, vrpn
Exposing an intersense cube via VRPN nihohit Precision Position Tracker (PPT) 5 09-10-2012 04:00 PM
intersense addTracker krimble Vizard 4 04-02-2012 09:57 AM
VRPN quaternion conversion from PPT from Intersense InertiaCube willemsn Precision Position Tracker (PPT) 0 07-20-2011 01:59 PM
