Working button
Is there anyway to create a working button (not button on the screen panel)?
For example, I created a car dashboard, it has a button to turn on/off video on the dashboard screen. Any advice and suggestions will be greatly appreciated. Thank you very much. Kind regards, Yudhi |
You could either toggle between two button models or two textures when the button changes state.
Hi Jeff,
Thank you very much for your response. Did you mean: I need to use "vizdlg panels", then "the button on the vizdlg panel" will toggle "the button on the car dashboard" and turn on/off the video on the dashboard screen". Regards, |
Hi Jeff,
Many thanks for your response. Did you mean: I need to use "vizdlg panels", where "the button of vizdlg panels" will toggle "the button on the car dashboard" and turn on/off the video on the dashboard screen. Means, I cannot toggle "the button on the car dashboard" directly (perhaps using something like grabber tool?). Apologies, I am new in this area although I have many years working with CAD. Thank you. |
Tags |
working button |
Similar Threads | ||||
A door question... left button mouse | Sakiot | Vizard | 3 | 08-26-2011 12:45 AM |
How to add a button tag? | jincheker | Vizard | 0 | 12-02-2009 08:34 AM |
Push a button | snoopy78 | Vizard | 1 | 07-20-2009 09:39 AM |
Create Button or Text | Chrissy2009 | Vizard | 1 | 07-15-2009 05:34 PM |
button problems | cade_mccall | Vizard | 3 | 02-22-2007 09:48 AM |
