Old 07-20-2009, 01:20 AM
snoopy78 snoopy78 is offline
Push a button
I want to push a button with my mouse and afterthat my object should rotate for a special amount.
This works, but I had to push the button again and again.
def onButton(obj,state):
  if obj == scene3.btnLeftRotate1:
    if state == viz.DOWN:
      object1.rotate(-1,0,0,'',viz.RELATIVE_LOCAL)
viz.callback(viz.BUTTON_EVENT,onButton)
I want to push the button one-time with my mouse and as long as I hold the button pressed, the object should move on and on.
Old 07-20-2009, 09:39 AM
You can use the vizact library to enable a timer while the button is down. Here is a simple script showing how to do this:
# Create model
model = viz.add('logo.ive',pos=(0,1,5))
# Create function to rotate model
def RotateModel():
	model.setEuler(90*viz.elapsed(),0,0,viz.REL_LOCAL)
# Create disabled timer to call RotateModel function
rotateTimer = vizact.ontimer(0,RotateModel)
rotateTimer.setEnabled(False)
# Create button
rotateButton = viz.addButton(pos=(0.9,0.1,0))
# Enable rotate timer while button is pressed
vizact.onbuttondown(rotateButton,rotateTimer.setEnabled,True)
vizact.onbuttonup(rotateButton,rotateTimer.setEnabled,False)
Create Button or Text Chrissy2009 Vizard 1 07-15-2009 05:34 PM
Trouble loading a .obj file into a scene through a button djones1010 Vizard 1 04-27-2009 11:51 AM
button events when drawing over gui elements moooh Vizard 2 04-10-2009 01:01 AM
button problems cade_mccall Vizard 3 02-22-2007 09:48 AM
on/off button bailenson Vizard 1 09-28-2004 05:13 PM
