Old 12-14-2006, 12:45 AM
giancamati giancamati is offline
Thumbs up Stereo Enhancement
Hello everybody,
I am using Vizard R3 with many successful results! Right now I am able to interact with FOBs, glove, and 3D objects.
To improve interaction, I use stereoscopic visualization. Right now, I enable it with viz.STEREO vertical Split. In this way, objects look "inside" my screen while I know that is possible to visualize objects outside the screen. (Passive stereoscopy).
Is there any parameter that I can manipulate to enhance stereoscopic visualization performance?
Thank you so much.
Giancarlo
Old 12-14-2006, 09:32 AM
While my understanding of stereo and your stetup is limited, I suspect the two paramters/commands you are most interested in is <window>.screenDistance and <window>.fov. Check these out in the Vizard command reference.
