Old 12-13-2006, 11:55 AM
pattie pattie is offline
Project .avi or .mpeg file
Hi:
I would like to project movies (.avi or .mpeg) files into the Virtual Environment so that the user is immersed "inside" the movie (usually a 180 degrees immersion).
Once the movie is made, is there an easy way to do this in Vizard?
thanks
Patrick
Old 12-13-2006, 11:59 AM
This should be very simple to do. Just create a cylinder with the correct texture coordinates and then apply the movie as a texture to the cylinder.
Old 02-06-2007, 09:09 AM
vizmaster vizmaster is offline
Question More then one?
Are you looking to show more then one movie at the same time? Like 10 movies side by side for 360 degrees. Each movie is 1024x1024. Giving you an effective resolution of 10240x1024 over 360 degrees. Is that do able? Would there be seams between the movies? What about synchronizing them?
VizMaster
