Old 11-07-2003, 10:40 AM
hotspur1 hotspur1 is offline
callback problem in v2.12
I've noticed with version 2.12 I can no longer change the callback function for a timer event without having Vizard crash on me. This was working fine in v2.11...
I have included a sample script (zip) using standard Vizard objects for you to try out. I've tried this on three separate computers with the same result.
Any workarounds or fixes...aside from having to rewrite programs?
Old 11-07-2003, 01:15 PM
Sorry about that, the bug has been fixed. There is no workaround for this, but I can send you a patch.
Old 11-07-2003, 01:48 PM
great - I think you have my email - you can get it from tobin. I'll let you know how it works out.
Old 11-07-2003, 07:20 PM
The patch won't install because it says either Vizard in not installed (wrong), or is the wrong version (wrong). Does it matter in the registry or wherever it is checking for the version that I have upgraded from v2.10? I will try deleting and re-installing version 2.12, then running the patch.
I've been successful after uninstalling and re-installing - not sure what the cause of that was....
Old 11-12-2003, 06:25 AM
unabhan unabhan is offline
I have quite the same problem with the callback function & timer event ...
Had to go back to the 2.11 version.
Having an nVidia card and using the nVidia 45.23 driver stereo options we would like to use the 2.12 version.
Is it possible to get the patch as well?
UnaBhan
Old 11-12-2003, 09:50 AM
Yes the patch is available for download. Remember, you must have 2.12 installed before you run the patch.
http://www.worldviz.com/download/
Again, sorry for the inconvenience
