Old 11-10-2006, 03:23 PM
k_iwan k_iwan is offline
Red face OSGedit...
Has anyone managed to run OSGedit under windows?
I need to create some particle effects, and I'm working mainly with OSG format so, I thought I want to give editor a try.
http://osgedit.sourceforge.net/faq.html
The problem I am having; even with OpenSceneGraph installed, it's still missing some .dll as if some directory are not registered in the path. I will have another go and I'll post some progress (if there's any )
Regards,
Iwan
Old 11-10-2006, 03:48 PM
I just installed osgEdit and it ran fine on my computer. Did you download the installer, or the zip file?
Old 11-11-2006, 02:23 AM
OSGedit...
just the zip file.. and when I run the osgedit it is complaining about a missing libgtkglext-win32-1.0.0.dll. is there an installer version of it?
Regards,
Iwan
Old 11-11-2006, 02:58 AM
Talking OSGEdit...case closed.
http://sourceforge.net/project/showf...ckage_id=54922
Thanks for pointing this one out for me. I didn't read in the main page that there is an installer for version 0.6.0. I spent quite a number of hours to get 0.6.1 working. This 0.6.0 version runs fine in my computer.
Regards,
Iwan
Old 11-11-2006, 03:39 AM
Unhappy Snow....
Hi Farshizzo,
I've been looking into your snow.osg which you posted sometime ago. Is it true that we can't even use OSGedit to create particles?
I could modify your snow.osg rather easily by using OSGedit... but I couldn't see any option in OSGedit to do this.
REgards,
Iwan
Old 11-13-2006, 10:34 AM
I've never used OSGEdit, so I'm not familiar with its capabilities. Are you needing a snow effect or just looking to create your own particle effects? Vizard 3.0 comes with a snow/rain rendering plugin. If you decide to switch to 3.0 I can provide you with a sample script.
Old 11-16-2006, 12:51 AM
Talking
We are using Vizard 3.0 beta 3. I would welcome a sample script. Thank you
Regards,
Iwan
Old 11-16-2006, 09:46 AM
I've attached a script which creates a snow effect with the plugin.
File Type: zip testPrecipitation.zip (478 Bytes, 2355 views)
Old 11-16-2006, 04:30 PM
Talking
Got it and tried it. This is lots better than the previous "snow.osg". Desert Storm, here I come!
Regards,
Iwan
