Old 10-25-2006, 08:13 AM
Chandan Chandan is offline
Unhappy error while setting material properties.
I get the following error while trying to set material attributes like sethardness()
the function is called as follows an example code:
import vizmat
viz.translate(viz.HEAD_POS,0,5,-10)
viz.lookat(0,0,0)
ground = viz.add('ground.wrl')
ground.collideplane()
ball = viz.add('ball.wrl')
ball.collidesphere()
ball.sethardness(0.1)
ball.reset()
ground.reset()
ball.translate(0,10,0)
ball.scale(0.6,0.6,0.6)
viz.phys.enable()
When I try to run this code, I get the following error:
Scaling image 'worlds/yellow.GIF' from (640,400) to (512,512)
File "myproj.py", line 14, in ?
AttributeError: 'VizChild' object has no attribute 'sethardness'
Scaling image 'worlds/blue.GIF' from (640,400) to (512,512)
Old 10-25-2006, 09:31 AM
setHardness is a method of VizPhysicsShape, not of VizNode/VizChild. Check the example again. In addition, the case of the letters in the method mater.
shape = ball.collideBox()
shape.setHardness(.5)
As we see here, setHardness is called on the object that returns from the collideBox() function. This is because you can have multiple collide shapes assosated with one node, such as the ball.
Check out this code to see multiple collide shapes:
box = viz.add('box.wrl')
box.collideBox()
ball = box.add('ball.wrl')
ball.scale(2,2,2)
ball.translate(0.5,-0.5,0)
box.collideSphere(pos=(0.5,-0.5,0))
