Old 10-11-2006, 03:56 PM
Jerry Jerry is offline
Intersect vs collision
Is it more efficient framewise to detect collisions with viz.intersect()
or physics collide callbacks?
Old 10-11-2006, 05:04 PM
viz.intersect() is different from physics collision callbacks. viz.intersect() returns collisions over a line. The physics callbacks are triggered when two objects collide. So it depends on what you need.
If you need line intersection tests, then viz.phys.intersectLine() will be much faster than viz.intersect. However, viz.phys.intersectLine() only returns results for objects that are part of the physics simulation. So you must define a collision volume for each node that should take part in the intersection test.
If you want know when two objects are colliding then you have two options. Use the physics collision callbacks. You must explicitly enable collision notifications for each object that you are interested in:
node.enable(viz.COLLIDE_NOTIFY)
Look at the duckcourt script for an example. The other option is to use the viz.phys.intersectNode command. This will return a list of all the nodes an object is colliding with. However, similar to the viz.phys.intersectLine() command, it only checks for collisions with objects that are part of the physics simulation.
In general it is more efficient to handle collision callbacks than to manually query for intersections every frame.
Old 10-11-2006, 08:09 PM
line touching cylinder
I am trying to detect when an on the fly line is in contact
with a cylinder. Which method would be most efficient?
Old 10-11-2006, 08:21 PM
In this case collision callbacks won't work, so you need to manually call the intersect function yourself.
Old 10-12-2006, 11:24 AM
FYI the collision callback method does work with an on-the-fly line if you
specify .collideBox(). It doesn't work with .collideMesh().
Old 07-12-2007, 05:21 PM
mjabon mjabon is offline
Why? Will the collision callbacks work while dragging something with the HD? That's what I'm trying to do....
Old 07-13-2007, 12:39 PM
Yes, the callbacks will still work when you are dragging an object. Like I mentioned above, you will need to explicitly enable collision notifications on an object for a callback to be triggered.
Old 07-16-2007, 03:27 PM
I have enabled collision on everything but it still never registers the callback. I did this:
made a bunch of screws and said this for each one:
screw.collideCapsule()
screw.enable(viz.COLLIDE_NOTIFY)
I also made a box:
currentBox.collideMesh()					#make a collision mesh so we know when screws hit it
currentBox.enable(viz.COLLIDE_NOTIFY)
Then I did this:
def onCollide(e):
	print "collision!"
	global allM1Screws, allM2Screws
	#Did a screw hit the box?
	if ((e.obj2 in allM1Screws) or (e.obj2 in allM2Screws)):
		#Change color of box
		e.obj1.color( random.choice( [viz.RED,viz.GREEN,viz.SKYBLUE,viz.YELLOW,viz.ORANGE,viz.PURPLE] ) )
viz.callback( viz.COLLIDE_BEGIN_EVENT, onCollide )
viz.collision(viz.ON)
I never enter the collision callback code
Old 07-17-2010, 02:57 AM
dwaik dwaik is offline
try doing this
currentBox.enable(viz.CONTACTS)
hope that was helpfull
