Old 09-30-2006, 07:32 AM
pattie pattie is offline
Vizlink problem
Below is a sample piece of code (numbered lines for clarity) that I play around with in order to make sure I understand the linking process.
1: import viz
2: viz.go()
3: block = viz.add('box.wrl')
4: block.translate(0,1.8,3)
5: marker = viz.add('marker.wrl')
6: marker.scale(0.1,0.1,0.1)
7: marker.translate(0,1.8,0)
8: link = viz.link(marker,block)
9: print "marker pos is: ", marker.getPosition()
10: print "block pos is: ", block.getPosition()
11: marker.translate(0,11,24)
12: print "marker pos is, after translation: ", marker.getPosition()
13: print "block pos is, after translation: ", block.getPosition()
14: link.remove()
15: marker.translate(0,1.8,41)
16: print "marker pos is, after remove: ", marker.getPosition()
17: print "block pos is, after remove: ", block.getPosition()
If I run this program, I notice that the block position (line 13), (the node being linked to the marker on line 8) is is not updated after the marker is translated (line11). I do not understand why. Shouldn't the block position be applied the translation too?
Furthermore, If I understand correctly, the remove() function is like an unlink command. Is that correct?
Thanks for your reply
Patrick
Old 10-02-2006, 10:55 AM
The link object only updates the position of the destination objects every update-cycle/frame so you have wait a frame before the block takes on a new position.
counter = 0
def onTimer(num):
	global counter
	if counter == 0:
		link.remove()
	if counter == 1:
		#marker.translate(0,1.8,41)
	counter += 1
viz.callback( viz.TIMER_EVENT, onTimer )
viz.starttimer( 0, .01667, viz.FOREVER )
Old 10-05-2006, 05:52 PM
VizLink problem
Thanks, Paul
Maybe it should be added in the help file, unless I missed it there.
Thanks for the help anyways
Patrick
