Old 07-20-2006, 01:05 PM
Vbents Vbents is offline
problem with sequential glasses
In our lab we are trying to use eDimensional flicker glasses to view Vizard. The graphics card is not nVidia, as the help file recommends, because the glasses do not work well with that card. So far the glasses' flicker does not sync with the screen's flicker.
Has anyone gotten this to work, or has any suggestions for what could be wrong. I followed the example code:
viz.go(viz.FULLSCREEN)
viz.viewdist(5)
Ben
Old 07-21-2006, 11:56 AM
tobin tobin is offline
What graphics card do the glasses recommend being teamed up with? Did you try and nVidia based card + "nvidia consumer stereo" driver configuration and that's what didn't work?
If you have a true OpenGL quad-buffered graphics card (any manufacturer) then issue viz.go(viz.QUAD) and it's possible that will work.
Old 07-22-2006, 03:53 PM
Unfortunately, eDimensional does not work with the nVidia drivers--we wouldn't choose eDimensional in retrospect.
The machine we are using has a Radon graphics card, and I will try your suggestion for quad-buffered rendering.
Ben
Old 07-23-2006, 04:25 PM
keep in mind that quad bufferng i generally only available on fairly highend graphics cards.
