Old 10-30-2021, 05:59 AM
Roy Roy is offline
Cedrus Response Pad in Vizard
What's the differences between vizcedurus and vizxid modules in Vizard 7?
There are already some posts about Cedrus response pad, but a bit confusing how to use it as a response device in Vizard.
For example, what' the easy or suitable way to use the Cedrus pad as a response device like a general keyboard to get the response time and pressed key?
Old 11-09-2021, 10:26 PM
I think vizxid is the more recent of the two modules. The following code has worked for other users with a Cedrus response pad. Does this work for you?
import viztask
#Connect to xid device
import vizxid
vizxid.open(18) #Default: port=1 , baudRate=115200
def TestReactionTime():
	#Add instruction label
	label = viz.addText('Press the spacebar to start the experiment\nWhen the red square turns green, press button 3 on the cedrus pad',viz.ORTHO)
	label.alignment(viz.TEXT_CENTER_CENTER)
	label.fontSize(24)
	viz.link(viz.CenterCenter,label)
	#Start expirement when spacebar is pressed
	#Remove the label
	label.remove()
	#Add quad to screen
	quad = viz.addTexQuad(viz.SCREEN)
	quad.setPosition(0.5,0.5)
	quad.setScale(4,4,4)
	#Data for getting values from wait conditions
	d = viz.Data()
	while True:
		#Set quad to red color
		quad.color(viz.RED)
		#Wait random amount of time
		yield viztask.waitTime( vizmat.GetRandom(1.5,2.5) )
		#Set quad color to green
		quad.color(viz.GREEN)
		#Wait for next frame to be drawn to screen
		yield vizxid.waitDraw()
		#Wait for button 3 on XID to be pressed
		yield vizxid.waitButtonDown(3,d)
		#Calculate reaction time
		reactionTime = d.time
		print('Reaction time:',reactionTime)
viztask.schedule( TestReactionTime() )
cedrus, response device
Cedrus Response Pad? Trevor Vizard 1 08-16-2012 05:26 PM
integrating brain-imaging response buttons with Vizard hrm Vizard 1 05-04-2012 07:24 AM
