Old 08-17-2020, 08:27 AM
BezierSpline BezierSpline is offline
Automating the publishing Process
Hello there!
I have been reading the forum for a few years now, and have finally encountered something i could not find an answer for in the documentation or with a bit of research here:
Is there a way to automate the .exe publishing?
Im working with a large codebase for an application in vizard and would love to be able to publish the .exe files without much human input.
Please note, i almost never add new files or resources to the application and already use the "Import publish settings" function for publishing.
Id really apprecite any input
Old 09-25-2020, 02:19 PM
A script needs to be compiled and then it can be published as an EXE. I don't think it's possible to automate it beyond what's mentioned in the documentation by adding publish paths, filters and directories
Publishing with external libs fabioped Vizard 2 06-08-2017 05:25 AM
Multiprocessing Process sleiN13 Vizard 2 08-01-2011 05:47 AM
Publishing and exe that uses Tkinter kevin Vizard 1 06-09-2011 04:02 PM
pass process to CPU shahramy Vizard 0 12-18-2010 11:45 AM
UnrealEd Process Plymouth Vizard 1 08-16-2006 10:33 AM
