Old 03-10-2020, 10:21 AM
natstj natstj is offline
Avatar distorted when imported from unity
I have an avatar from unity that I want to animate with Mixamo and import into Vizard. I am using this Vizard tutorial as a guide: https://www.youtube.com/watch?v=M7fUgkuejgs. I am having the following problem: when I import my avatar into the vizard inspector as a .fbx (the original file type), the avatar appears distorted. If I convert the file to a .gltf and then import it into the inspector, it is not distorted. However, I need it in the .fbx format in order to animate it with mixamo. Do you have any suggestions? Thank you! (pictures are attached)
Best,
Natalie
ID:	986   Click image for larger version
Old 03-10-2020, 02:45 PM
Hi, would you be able to provide a link where I can download the file? FBX avatars from Mixamo should work without any issue from Mixamo. Can you also try directly downloading from Mixamo again and then going into Inspector? Also, what version of Vizard are you using?
Unexpected Avatar lookAt() behavior when using yield statements chris2307 Vizard 2 12-17-2013 03:58 AM
Avatar & Motion Capture Interface Angie Vizard 1 08-05-2010 07:17 PM
Collision of an avatar with a quad Frank Verberne Vizard 8 06-04-2008 10:44 AM
How to make avatar's eyes to blink when speaking michelcm3 Vizard 12 01-15-2008 09:48 AM
