Old 09-03-2019, 05:15 AM
josephredfern josephredfern is offline
Extracting high precision depth map from scene
I'm new to using Vizard, and attempting to extract high-precision depth data from a scene.
At the moment, to do this, I am using:
depth = viz.addRenderTexture(format=viz.TEX_DEPTH_32)
float_buff = depth.saveToBuffer('<raw>', dataType=viz.GL_FLOAT)
size = depth.getSize()
w = size[0]
h = size[1]
d_float = np.fromstring(float_buff, np.float32, w*h)
np.save('depth.npy', d_float.reshape((w, h)))
This allows me to save the values of the depth render texture to a numpy array... but I have a few questions:
  • What units is this depth texture in? For the piazza scene, all/most values seem to be around 0.9. Is there a way of converting this to meters?
  • The dimension of the resulting texture is always 512x512. How is this controlled?
  • Is this the correct way to extract the depth? Is there a way of using depth.save() to store an uncompressed numpy array (rather than png/jpg etc?)
Any guidance would be appreciated.
Joe
Old 09-05-2019, 05:24 PM
The depth buffer on GPUs is non-linear, in order to provide greater precision to nearby objects.
You can convert a raw depth buffer value to linear and world units using the following code:
z = <raw depth buffer value>
znear = viz.MainWindow.getNearClip()
zfar = viz.MainWindow.getFarClip()
# Compute normalized linear depth value (0-1 range)
linear = (2 * znear) / (zfar + znear - z * (zfar - znear))
# Compute world depth value (distance from view plane)
world = (2.0 * znear * zfar) / (zfar + znear - (2.0 * z - 1.0) * (zfar - znear))
Old 10-28-2019, 05:53 AM
Hi Jeff,
I forgot to reply to this at the time -- but thank you for your answer, it solved the issue for me.
Copying Scene? Brett Lindberg Vizard 0 08-29-2009 12:56 AM
