Old 07-31-2019, 02:40 AM
zumbay zumbay is offline
Reading files from executable (EXE)
I have two questions which relate to reading files from a vizard exported executable.
One issue I face, is creating an executable with multiple GB worth of resources and models. Currently, Vizard throws an error when I try to publish as EXE. I assume the size is the issue. Is it possible to export the script as an executable and have the resources and models in the same folder, so that the executable can read them in on the fly?
The other question relates to a different application, where I would like to read in a text file in the executable (in same folder as the executable) and use the content of the text file on the fly. What is the best way of doing this?
Cheers!
Old 08-06-2019, 01:23 PM
You can try using the .getPublishedPath option
https://docs.worldviz.com/vizard/lat...lishedPath.htm
Let me know if that works what you're trying to do.
Seeing errors finding files in an executable Enlil Vizard 2 09-27-2010 11:34 AM
How to edit the skin tones of the complete characters' cfg files? vEsotu Vizard 3 09-23-2008 12:07 PM
Writing text files with executable adimov Vizard 1 03-21-2008 03:21 PM
Error when playing wav files...? vjonshih Vizard 1 05-23-2005 12:21 PM
loading large wav files in vizard tommahhh Vizard 1 05-16-2005 03:23 PM
