Old 07-27-2019, 09:01 PM
iamnoone87 iamnoone87 is offline
Using Vizconnect Tools in Multiple Scenes
Hello, everyone.
I am developing a VR application featuring a multiple scenes and am using Vizconnect so that the user of the application can use the highlighter to press buttons and a grabber to grab objects as need be. The highlighter and grabber tools are visible in the main scene, but when move to another scene using, for example, viz.scene(8) , I cannot see the highlighter or grabber tools. I tried to no avail initializing the tools globally and locally. Is there a way that can implement the tools in a scene other than the main scene? Thanks.
Old 08-16-2019, 01:14 PM
A tool is parented to a model, such as an avatar hand, and so the model would need to be cloned into each scene that you switch to.
grabber, highlighter, scenes, vizconnect
Regarding changing &using multiple tools at same time through vizconnect rajnishv Vizard 7 09-08-2016 05:48 AM
Zspace display in Vizconnect JB_HP_Viz Vizard 5 06-05-2015 04:28 PM
Switching between input devices setup in vizconnect and not using vizconnect JB_HP_Viz Vizard 1 01-20-2015 06:19 AM
Vizconnect Save As Dialog Jeff Vizard 0 05-01-2014 10:45 AM
vizinfo in multiple scenes vadrian Vizard 9 02-03-2005 11:49 AM
