Old 12-07-2018, 04:09 AM
qwartz qwartz is offline
Registered User
Question Detect Hands of Avatar (set them as target)
Hi
I use the Oculus Rift with a vizconnect configuration where I've added the "Mark" avatar's hands. I want to touch objects and when they are touched they should change state (e.g. color).
My objects have sensors and I can achieve the desired change in state when the viewpoint is near the objects. Now I want to extend the target from the viewpoint to the hands of the avatar (so that when the hands are near the objects, they - the objects - change state).
I tried something like that:
viewTransform = vizconnect.getDisplay().getNode3d()
#viewTransform = vizconnect.getAvatar#.getNode3d()
target = vizproximity.Target(viewTransform)
manager.addTarget(target)
but it doesn't work. Anything else to try?
Old 12-12-2018, 04:28 AM
This maybe difficult using the mark avatar hand. Since the hand is only a mesh and not a distinct 3d node it's not possible to get a handle directly to it and set it as a proximity target. You could try using the head and hands avatar instead. Attached is an example.
avatar, sensor, sensor proximity, vizconnect
vizproximity hint - debug 2D areas related to a source only after adding a target! fordprefect Vizard 1 12-15-2014 01:37 PM
Unexpected Avatar lookAt() behavior when using yield statements chris2307 Vizard 2 12-17-2013 03:58 AM
Collision of an avatar with a quad Frank Verberne Vizard 8 06-04-2008 10:44 AM
How to make avatar's eyes to blink when speaking michelcm3 Vizard 12 01-15-2008 09:48 AM
