Old 10-19-2018, 10:34 AM
seowen1 seowen1 is offline
Exclamation Creating InfoPanel on screen with HMD vizconnect
Hi there,
I'm trying to create an InfoPanel from the default vizinfo.InfoPanel class. It runs fine in desktop mode, but with an HMD vizconnect running the InfoPanel is being drawn twice on the monitor. Almost as if the InfoPanel is being rendered in stereo mode, and the rest of the scene is being rendered with the left eye on the monitor.
The purpose of this is to create an "Instructor View" on the monitor with controls that are only visible to the instructor.
Old 10-24-2018, 10:21 PM
Can you attach the vizconnect file you are using and example code used in Vizard to add the panel?
Old 10-25-2018, 01:49 PM
Sure thing. I have done so here. I deleted all the project specific stuff, so hopefully it runs for you okay. I want to see just one InfoPanel on the monitor.
Old 10-27-2018, 09:52 PM
The mirrored window on the monitor displays correctly in mono, right? If you run the following code with your vizconnect file, do you see the panel rendered once?
import vizconnect
import vizinfo
vizconnect.go(vizconnect_config_vive.py)
viz.addChild('piazza.osgb')
vizinfo.InfoPanel('Panel Test')
Old 10-29-2018, 07:05 AM
No, I am still seeing it rendered twice. I've uploaded a screenshot of what I'm seeing when I run your code.
Thank you for looking into this, it's really becoming a problem.
Old 10-30-2018, 07:05 AM
Do you see the panel rendered twice when running the following code:
import vizinfo
import steamvr
hmd = steamvr.HMD()
hmd.setMonoMirror(True)
Old 10-30-2018, 08:12 AM
Yes, I still see two panels on the monitor view. I'm using Vizard 5.8, so I'm unsure if there is any difference in our steamvr.dle plugins.
Old 11-01-2018, 07:27 AM
Any updates on this? Looking for a quick solution. Can't seem to work through the issue myself. Thanks!
Old 11-06-2018, 09:32 PM
Add the following line of code to render the panel only once:
panel.renderToEye(viz.LEFT_EYE)
Old 11-07-2018, 08:55 AM
That did the trick! Thank you!
gui, hmd, mono, render, stereo
Switching between input devices setup in vizconnect and not using vizconnect JB_HP_Viz Vizard 1 01-20-2015 06:19 AM
Vizconnect Save As Dialog Jeff Vizard 0 05-01-2014 10:45 AM
Screen Size and Scaling javadi Vizard 2 04-02-2013 06:56 PM
Attach a TexQuad to pit.osgb screen Ducky Vizard 1 01-17-2013 03:57 PM
position of html-file on screen active_world Vizard 1 05-16-2008 08:24 PM
