Old 07-24-2018, 03:15 PM
jwhopkin jwhopkin is offline
Lightbulb Disable lighting on specific object?
Hi, I am working with an environment model that has already gone through baked lighting and works well without the given headlight or any additional lights in the scene. I also have a model which I would like to utilize visard/inspector lights for. Is it possible to disable those lights for the environment model and have them work for only the specific model i want them to work for? The override function in inspector doesnt seem to do the trick. Thanks!
Old 07-25-2018, 02:44 AM
Yes, it is possible to disable lighting on an individual object. Try using the node3D.disable command with the value viz.LIGHTING.
baking, lighting
Object Collision Mattrat3000 Vizard 1 12-15-2017 02:30 AM
Determine specific quad from intersection Novakin Vizard 1 02-19-2016 02:25 AM
how to move seperately? nasr Vizard 2 05-11-2009 02:57 AM
