Old 05-25-2018, 12:00 PM
zumbay zumbay is offline
steamvr controller for htc vive unresponsive
Maybe somebody can help with this,
I am using the smi plug-in for the htc vive and now my vive controller is not responsive anymore - last time the same script worked was on the 8th of May and it wasn't tried since.
Not sure if this is related to the latest steamvr updates, but it matches the timing!
# Connect to Vive eye tracker
smi = viz.add('smi_vive.dle')
eyeTracker = smi.addEyeTracker()
# Add controllers
for controller in steamvr.getControllerList():
	# Create model for controller
	controller = controller
	controller.model = controller.addModel(parent=navigationNode)
	controller.model.disable(viz.INTERSECTION)
	controller.distance = 1
	viz.link(controller, controller.model)
def printer():
	print('button')
vizact.onsensordown(controller, steamvr.BUTTON_TRIGGER, printer)
If I comment out the ""addEyeTracker" line onsensordown works, if not - nothing happens.
I am running Vizard5 and SteamVR beta Version 1527202199.
Old 05-25-2018, 03:50 PM
Do you see any errors in the Vizard output?
Old 05-25-2018, 11:02 PM
No errors. Button presses simply do not yield any reaction.
I replicated this now in all our previously working eye tracking scripts.
HTC Vive Controller not working Seadna Vizard 4 04-21-2021 07:40 AM
Check for running SteamVR A Wundlechner Vizard 2 01-11-2018 01:03 AM
disabling the system button in vive hand controller pitbool Vizard 2 06-02-2017 02:41 PM
Controller Coordinates and Euler angles biomech_dave Vizard 2 09-12-2016 04:25 PM
