Old 05-19-2018, 11:18 AM
amir amir is offline
Moving Diagonally in Computer Display
Hi there,
When using just the keyboard and mouse and trying to move forward in a straight line in the pit.py simulation, I move forward diagonally to the right instead. This diagonal movement happens in every direction in the X/Z plane.
This happens with the default pit.py script.
Is there anything I can do to fix this diagonal motion?
Old 05-23-2018, 04:41 PM
I'm not able to reproduce this. Does this occur if you start up the script and move forward with the 'w' key and without moving the mouse?
Old 05-25-2018, 02:03 PM
Must've been a display issue. When I run the scripted as docked it works fine.
display, movement, pit
Using VRPN and INtersense to Connect Computer A with Computer B vlc Vizard 5 06-05-2015 04:33 PM
help with moving objects to different locations sportykourty Vizard 1 03-24-2015 10:37 PM
Duplicate HMD display on primary monitor, with eyetracking info performlabrit Vizard 3 09-19-2014 11:44 AM
Formatting Vizrad's Computer ohad Vizard 1 03-15-2010 01:54 PM
Support for Philips IC3D Autostereoscopic display mspusch Vizard 0 07-13-2006 05:14 PM
