Old 05-02-2018, 09:04 AM
amir amir is offline
Maya to Vizard
I am building 3D models in Maya and exporting them as OSG files. However, when I open them in Inspector, I come across a few issues.
  1. The colors or textures applied in Maya don't show up.
  2. The imported object shows up as mutiple geodes each with one geometry. A lot of these geodes are just one face of an object or a transform of some kind.
  3. The object is partially distorted - e.g. holes and crooked edges.
Are there some best practices when going from Maya to Inspector?
Old 05-02-2018, 11:52 AM
We support the OSG workflow from 3ds Max to Vizard. Do you have access to 3ds Max? If not, you could try exporting to FBX from Maya and loading that in Vizard.
inspector, maya, modeling, osg, osgb export
Update on exporting from Maya to Vizard? performlabrit Vizard 4 04-29-2014 03:10 PM
vizard suport maya 2010? or collada? for bone animation Darkmax Vizard 2 09-02-2010 02:48 PM
Exporting from Maya in Vizard Elittdogg Vizard 2 04-03-2008 08:51 AM
Exporting from Maya to Vizard jfreeman Vizard 2 06-30-2005 03:14 PM
