Old 04-26-2018, 06:51 AM
tianmoran tianmoran is offline
Unhappy Avatar animation -- change states
I want to change my avatar's states according to conditions. However, there are some problems with the codes:
def ani_change():
	female1 = viz.add('Avatars/Avatars/CC2_f001_hipoly_A1_v2.cfg')
	female1.setPosition(1,0.5,1)
	female1.setEuler(90,8,0)
	bloNo = 10
	Code = [0,1,0,1,0,1,0,1,0,1]
	for block in range(bloNo):
		female1.visible(viz.ON)
		if Code[block] == 0:
			female1.execute(8,0,0,freeze =  True)
			female1.setAnimationSpeed(8,0)
		elif Code[block] == 1:
			female1.execute(3,0,0, freeze = False)
			yield viztask.waitTime(3)
			for j in range(10):
				female1.blend(3,1-float(j/10))
				female1.blend(8,float(j/10))
				yield viztask.waitTime(float(j/2))
			yield viztask.waitTime(0.5)
			female1.state(8)
		female1.visible(viz.OFF)
		yield viztask.waitTime(5)
viztask.schedule(ani_change())
Here are the problems:
1) The avatar's states don't change;
2) The amplitude of the avatar's movement decrease across different trials. Eg. The highest point that her arm could reach is always lower than in the previous trial.
Many thanks!
Old 04-30-2018, 12:05 PM
I tested this code with the vcc_female avatar included with Vizard and it alternates between two animations. Does that work for you?
Old 05-02-2018, 12:20 PM
Thank you for your reply! I tested the codes below:
def ani_change():
	female1 = viz.add('vcc_female.cfg')
	female1.setPosition(1,0,10)
	bloNo = 10
			female1.execute(2,0,0,freeze =  True)
			female1.setAnimationSpeed(2,0)
			female1.execute(11,0,0, freeze = False)
			for j in range(10):
				female1.blend(11,1-float(j/10))
				female1.blend(2,float(j/10))
			female1.state(2)
So what I expect in this case is that the female avatar stops then run for a while then stop again, which means she should switch between running and stop for five times. However, in this case she just runs then stops.
So how can I amend the codes to achieve my goal?
Old 05-02-2018, 03:56 PM
The example code below alternates between running and idle animations:
import viztask
viz.addChild('piazza.osgb')
female = viz.add('vcc_female.cfg',pos=[0,0,5],euler=[90,0,0])
def ani_change():
	for i in range(5):
		female.state(11)
		female.state(1)
		yield viztask.waitTime(1)
Old 05-03-2018, 11:57 AM
Hi Jeff,
My initial goal in the first paragraph of codes is to let the avatar sit idle then frozen like a statue for a while. Then repeat this circle. Which is required by the experiment.
So is there a good way to solve this?
BTW, what could be the reason for the second problem?
aavatar, animation
Walking Animation of Avatar pradeep Vizard 1 07-03-2014 03:35 AM
Collision and avatar animation shahramy Vizard 2 10-26-2010 11:47 PM
changing between avatar states dan12345 Vizard 1 06-23-2008 01:39 PM
