Old 04-16-2018, 07:12 AM
leviz1 leviz1 is offline
Question Adding ceiling to 3d room model
I'm trying to build a virtual environment that will look relatively natural for an experiment and could use some help:
I have loaded a model of a room from 3d warehouse but need to add a ceiling for it to look normal
Is there a way to add a simple neutral color/ pattern ceiling at a specific height? the room I need it for is pretty big so the ceiling should be long/ with length by demand
couldn't find anything suitable on 3d warehouse.
Thank you in advanced
Old 04-17-2018, 12:08 PM
You should be able to load it into SketchUp and make the modification there. There are many online tutorials for SketchUp modeling. The following is a tutorial related to the SketchUp to Vizard workflow:
https://sites.google.com/worldviz.co...-workflow/home
ceiling, color, pattern
adding new model in Vizard aloktripathi008 Vizard 1 06-22-2015 03:49 PM
The problem of adding two .ive models hengshan.li Vizard 1 08-08-2011 12:04 AM
Awkward neck/shoulder connection when adding custom head to vcc model. vEsotu Vizard 5 10-09-2008 05:07 PM
