Old 04-12-2018, 12:14 PM
amir amir is offline
Translating Object in Inspector
All of a sudden when I try to translate an object in the Inspector, I translate the scene relative to that object instead.
I'm not sure how this happened. Anyone have an idea on how to revert back translating the object instead?
Old 04-17-2018, 01:30 PM
Make sure the object you want to move has a transform node associated with it and that it is selected in the scene graph before activating one of the transform modes.
Old 04-26-2018, 05:38 PM
In addition to that, check your coordinate space. (see attached)
Old 04-30-2018, 12:50 PM
Adding the transform node worked! Thanks!
inspector
Object Collision Mattrat3000 Vizard 1 12-15-2017 02:30 AM
Getting an object location chris2307 Vizard 4 01-10-2017 05:43 AM
Rotate object around mainView? performlabrit Vizard 3 12-19-2013 07:31 AM
