Old 02-14-2018, 11:20 PM
saravanan.balak saravanan.balak is offline
How to make my scenes follow my ball?
I want my scenes to change when the ball moves from one position to another.
import vizinfo
import vizdlg
import vizinput
import time
import viztask
data = viz.Data()
#viz.mouse(viz.OFF)
light1 = viz.addLight()
light1.setPosition(12.5,0,4)
light1.setEuler(0,20,0)
main=viz.MainView.setPosition(0,0,0)
env = viz.addChild('I:\Vi\File20171.dae')
env.setPosition(12.5,-1,3)
pos = env.getPosition()
orientation = env.setEuler(0,0,0)
ball = viz.addChild('volleyball.osgb')
ball.setScale([0.5,0.5,0.5])
path = viz.addAnimationPath()
points = [ [12.5,-1,3],[-13.999999237060547, 1.399999976158142, 13.5],[-35.59999923706055, 2.399999976158142, 12.5], [-47.979998779296875, 1.2999999523162842, 16.0], [-38.29999923706055, 1.399999976158142, 16.0], [12.5,-1,3] ]
for x,pos in enumerate(points):
path.addControlPoint(0.5*x,pos=pos)
path.setLoopMode(viz.LOOP)
path.play()
link = viz.link(path,ball)
link2 = viz.link(link1,env)
Old 02-15-2018, 08:14 AM
rajnishv rajnishv is offline
Pls find the below code and use it to integrate with your program code.
import vizcam
camera = vizcam.PivotNavigate()
camera.setDistance(5)
def moveCamera():
	while True:
               # Get the handle of the 3D Model as taken below
		lookAtPos = avatar.getBone('Bip01 Pelvis').getPosition(viz.ABS_GLOBAL)
		lookAtPos[1] = lookAtPos[1] + .5
		camera.setCenter(lookAtPos)
		camera.updateCenter()
		yield None
viztask.schedule(moveCamera())
Thanx & Regards
Mr.Rajnish Vishwakarma
Physics: Ball Bounces Unexpectly Based Upon Size + Ring Collision Shape mhead10 Vizard 3 11-02-2012 01:44 PM
Strange Ball Joint behaviour mkmatlock Vizard 1 11-04-2010 04:49 PM
moving and object by mouse but don't know how to stop the movement nlfrnassimi Vizard 8 04-26-2009 07:23 AM
how can I stop an action? nlfrnassimi Vizard 4 02-13-2009 12:59 AM
How to make avatars to follow terrain while walking? yyang Vizard 1 08-04-2008 02:54 PM
