Old 12-25-2017, 12:49 PM
fivel_lab fivel_lab is offline
vizconnect getMovementScale
Hello
We are trying to use vizconnect's <WrappedAvatar>.setMovementScale() but we don't see any changes in the behavior of the avatar when it is moving. The vizconnect configuration uses Microsoft Kinect/FAAST as a tracker.
I have confirmed that I can change the movement scale VALUES:
SCALE = .1
myAvatar = vizconnect.getAvatar()
print 'Original movement scale: ' , myAvatar.getMovementScale()
myAvatar.setMovementScale([SCALE , SCALE , SCALE ])
print 'New movement scale: ' , myAvatar.getMovementScale()
but like I said above, this does not appear to do anything to the movement of the avatar. I've used values of SCALE as low as 1e-23 and as high as 10000, but the rendered movement seems identical no matter what the value is!
What does this method do, exactly? Am I missing some critical step to get it to work? Thank you!
Any guidance would be greatly appreciated!
Old 12-26-2017, 06:45 PM
It looks like this command is not working with all avatar types. I just tested and it works with the head and hand avatar but not the mark avatar. You should be able to get the same result by applying a scale factor to the tracker links instead:
trackerLink = vizconnect.getTracker('head_tracker').getLink()
# Scale movements along ground plane by factor of 5
trackerLink.postScale([5,1,5])
Old 12-29-2017, 11:39 AM
great thanks.. we will check that out. Two questions:
1) if we want to use the vcc_male avatar, how do I figure out what the named key should be for the tracker in line 1 of your code? 'head_tracker' doesn't seem to work.
2) Can you give me a little more detail on the scaling function? I'm assuming that, if the tracker moves x units (let's say in the z-plane), then postScale([1,1,5]) would move the rendered avatar 5x units. Is that true? Also, can the scaling constant be less than zero?
Old 01-02-2018, 08:55 AM
Hope you had a nice New Year. Just following up on this post. Any advice? Thanks!
Old 01-04-2018, 02:58 AM
The tracker name is the name given in the trackers tab of vizconnect.
Yes, that should work
It can be a number between 0 and 1 if you want to reduce the speed.
3D monitor display with Vizconnect rdkirkden Vizard 2 09-14-2017 02:17 AM
Regarding changing &using multiple tools at same time through vizconnect rajnishv Vizard 7 09-08-2016 04:48 AM
Zspace display in Vizconnect JB_HP_Viz Vizard 5 06-05-2015 03:28 PM
Vizconnect Save As Dialog Jeff Vizard 0 05-01-2014 09:45 AM
