Old 12-16-2017, 02:49 PM
ariekazy ariekazy is offline
How To Get All The Drawables In A Model As Nodes
Hiii
I want to get access to all the children of a node. I know I have to use node.getChild but that only gives me nodes which are children of that node. If I want to get access to all the drawables also, what should I do. This the support it shows the getChild don't work with drawables. So what should I do..
Regards
Shen
Old 12-20-2017, 08:38 AM
The node3D.getNodeNames command returns a list of scene graph node names. I don't think drawables are nodes in the scene graph though. Can you describe a bit more what you're trying to do.
Highlighter tool on nodes in model Seadna Vizard 5 02-11-2016 05:17 AM
How to get all the Drawables in a model as Nodes pankaj bansal Vizard 2 01-02-2013 10:30 AM
Internal nodes of loaded model files? dtidrow Vizard 2 05-12-2009 08:55 AM
