Old 07-17-2017, 03:43 AM
manuel manuel is offline
Mixamo
Hi
I have a problem by using mixamo avatars. How is it possible to make them speaking?
PS I worked with "import speak_sync" with the HD Characters from rocketbox. But this is not possible with mixamos.
best
Manuel
Old 07-18-2017, 08:14 AM
Does the character have a jaw bone? If so, try adding the jaw bone name to the character's .cfg file.
Old 07-19-2017, 06:25 AM
no, it doesn't have a jaw bone (there is only "HeadTop_End, RightEye,LeftEye" for head bones). And that is the main problem. How can I get access to the JawBone. Does Worldviz (or anybody else) have a workflow (Mixamo > Inspector > Vizard) for sepaking avatars?
Old 07-27-2017, 03:36 AM
sbilleter sbilleter is offline
same issues
Hi everyone,
It seems that I have the same problem, because we are trying to use the mixamo avatars, but in some cases we need them to speak and for now it's impossible.
Is there any solutions about it ?
Best,
Stéphane
Old 07-27-2017, 11:36 PM
Currently this is not possible with the direct workflow. To do this, you would need to import the Mixamo fbx character into Max, add a speech morph, and then export to Cal3D for use in Vizard.
