Old 05-23-2017, 03:02 PM
VizMars VizMars is offline
Import viewpoint from 3rd party software
Is there an option to import the viewpoint that's used in a 3d design sofware, especially Sketchup, in Vizard?
I wonder how I can setup the corresponding viewpoint for an experiment using a vizcave powerwall.
Old 05-24-2017, 12:23 AM
It looks like there is a transform node called 'skp_camera_Last_Saved_SketchUp_View' that shows up in the collada model exported from Sketchup. However, you could also navigate in Inspector and then right click and copy the camera's position and euler values. If you are using vizcave powerwall code directly without vizconnect then set the CaveView position to place the user at a specific location in the scene. See the section on viewpoint movement in the vizcave documentation for more information.
Old 05-24-2017, 08:17 AM
You are right, there is a node called 'skp_camera_Last_Saved_SketchUp_View'. But I don't know how to extract the camera's position and euler values from this node. Can you tell me how to do this?
Old 05-30-2017, 05:18 AM
I would suggest setting up the viewpoint in Inspector. It looks like the saved view from SketchUp may not be scaled and rotated correctly according to Vizard's coordinate system.
Old 05-30-2017, 07:05 AM
It would be great if I could try to apply the view from SketchUp to the model in Vizard as I need the same viewpoint from which the model was exported. Also, it looks like the saved view is displayed in the right way in Inspector in my case. Can you provide the Vizard code for getting the camera's position and euler values from this node?
Old 05-31-2017, 02:35 AM
First get a handle to the transform node and then you can get its position and orientation:
model = viz.addChild('model.dae')
viewNode = model.getTransform('skp_camera_Last_Saved_SketchUp_View')
pos = viewNode.getPosition(viz.ABS_GLOBAL)
ori = viewNode.getEuler(viz.ABS_GLOBAL)
Old 05-31-2017, 06:21 AM
Thanks Jeff, that did the job for me!
powerwall, sketchup, viewpoint
Regarding Viconnect viewpoint rajnishv Precision Position Tracker (PPT) 3 03-21-2017 12:03 AM
Regarding viewpoint with vizconfig,addFloatRangeItem&Storing viewpoint in PREFERENCES rajnishv Vizard 0 06-27-2016 04:57 AM
moving at different speeds Saz Vizard 8 06-07-2011 06:02 AM
Arrington - Ethernet ViewPoint Client jaclyn.bill Vizard 3 10-23-2009 11:43 AM
