Old 05-12-2017, 05:19 PM
Canucks Canucks is offline
Image Warping
Do you need to use image warping software if you wanna project your Vizard program on a screen? Does Vizard have a built in function for it?
Old 05-15-2017, 07:32 AM
If you want the projected image to change based on a tracked user and their position relative to the screen use the vizcave library. If you want to blend images from multiple projectors or warp the image to to fit a display surface (e.g. curved) then you would need 3rd party software to do that.
Old 05-15-2017, 07:37 AM
Also, vizconnect has CAVE and powerwall options in the display tab of the advanced configuration menu that generate the vizcave code for you.
image, screen
Oculus DK2 image warping ichitaka Vizard 1 07-24-2015 01:02 PM
wrong background color in interlaced stereo image rlh001 Vizard 4 09-25-2013 05:21 PM
360 panorama image cube using as darts target and record the xy coordinates mshukun Vizard 2 03-14-2013 07:17 AM
View an image on the Fakespace HMD roman_suvorov Vizard 16 05-23-2008 08:51 AM
