Old 03-20-2017, 03:04 AM
Ultim Ultim is offline
Point of an intersecting line and plane
I am trying to work with moving objects using the mouse.
for doing this I want to calculate the position of the mouse on XY plane.
When the XY coordinates are known i want to move the ball to those XY coordinates.
I have a ball in my world which will be the object of moving.
here is the code so far:
plane = vizshape.addPlane()
plane.setPosition(0,0,ball.getPosition[2])
mouseposition = Camera.main.ScreenPointToRay(Input.mousePosition);
I tried to use viz.intersect but got a lot of errors.
do you guys have any advice.
With kind regards.
Old 03-20-2017, 03:46 AM
You could use the viz.pick command to get the point of intersection between the mouse and the object it is pointing at. Here's an example:
import vizshape
dojo = viz.add('dojo.osgb')
sphere = vizshape.addSphere(radius=0.1,color=viz.GREEN)
sphere.disable(viz.PICKING)
def moveSphere():
	info = viz.pick(info=True)
	point = info.point
	sphere.setPosition(point)
vizact.onupdate(0,moveSphere)
Find collision point of line and arbitrary object asdf Vizard 2 01-28-2013 11:04 AM
