Old 03-07-2017, 09:29 AM
Rob Rob is offline
Link vizconnect display to Viz.mainview
Hey,
I want to link vizconnect display to viz.mainview so it inherits the same actions as whats being done for the mainview.
However, I cannot figure out how to do this.
vizconnect.go('vizconnect_config.py') ## Vizconnect movement
movement = vizconnect.getTransport('main_transport') ## links movement to the walking transport in viz connect
movement.setMovementSpeed(0) ## set movement speed to 0 for main menu scene
newobject = viz.add('beachball.osgb',scene=viz.Scene2)
newobject.setPosition([.5,50,0])
#viz.link(movement.getNode3d,newobject) ## this links movement but I cannot set a new Y position for the object at all.
#viz.link(vizconnect.getDisplay,viz.MainView) ## does not work either
How would i get it to link to the mainview without messing up anything thats been done?
Old 03-07-2017, 09:16 PM
The display has a view associated with it, which is the mainview by default. If you parent the display to a tracker or transport the view will move with that tracker or transport. If you don't need to change the hierarchy on the fly then you can set the display's parent in the scenegraph of the vizconnect GUI.
Vizconnect Display Issue ghostx Vizard 3 07-31-2016 08:46 PM
apply transformations on vizconnect link dcnieho Vizard 2 06-14-2016 07:11 AM
Zspace display in Vizconnect JB_HP_Viz Vizard 5 06-05-2015 04:28 PM
Switching between input devices setup in vizconnect and not using vizconnect JB_HP_Viz Vizard 1 01-20-2015 06:19 AM
Duplicate HMD display on primary monitor, with eyetracking info performlabrit Vizard 3 09-19-2014 11:44 AM
