Old 03-06-2017, 05:20 AM
zumbay zumbay is offline
Execute function at high sampling rate
I have an input device which can sample at a higher rate then the refresh rate of my monitor. What is the best way to save the data from that device?
Will calling a function which saves the data (e.g. using sensor.getData()) with vizact.ontimer(0.004, savedata) yield an accurate result? And how will it behave when the scene is rendered?
Old 03-06-2017, 10:43 PM
Vizard's main loop runs in sync with the display's refresh rate. So you won't be able to save out data at a higher rate.
You could try disabling vsync to get faster rates but then you may have tearing.
Physics engine update rate and display rate zharuViz Vizard 12 10-28-2013 06:52 AM
Frame rate issue kopper Vizard 2 06-09-2013 10:53 AM
