Old 03-05-2017, 11:11 AM
DJV DJV is offline
Adjusting point size of point cloud
http://docs.worldviz.com/vizard/comm.../pointSize.htm
I think that the above link is what I am looking for but I am unable to use it in my code. If I had an example I might be able to have better results.
I'm trying to increase point size in a cloud. Cloud compare has varables but the default is 1. No matter what you make it the default is one. Can anyone help me adjust the points to a larger size? I am trying to get a cloud less pixelated by this method.
Thanks in advance.
Old 03-05-2017, 10:26 PM
What is the format of the model that you are loading? The following code worked for me using a .3dc model:
model = viz.add('model.3dc')
vizact.onkeydown('1',model.pointSize,1)
vizact.onkeydown('2',model.pointSize,2)
vizact.onkeydown('5',model.pointSize,5)
Old 03-06-2017, 05:12 AM
DJV DJV is offline
I have a PLY that I converted to OSGB in Inspector
Thanks - I'll try the code and report back.
Old 03-06-2017, 06:54 AM
DJV DJV is offline
Thanks Jeff - That worked!
I appreciate your time.
Point Cloud Dissapearing Seadna Vizard 2 11-16-2015 01:47 AM
Viewing mesh/point cloud in vizard ecatcom1 Vizard 1 01-20-2015 05:31 AM
Point cloud library agrima Vizard 0 07-05-2014 10:57 PM
animate an object using 5dt data glove 5 ultra agrima Vizard 3 07-01-2014 11:17 AM
Unexpected Change of Window Size javadi Vizard 7 07-23-2013 02:56 PM
