Old 02-27-2017, 08:11 PM
mahesathya mahesathya is offline
collecting coordinate points of an object
Hello everyone
I'm a beginner in Vizard and I'm currently trying to map the coordinate points of microscribe and virtual object.
How to collect the coordinate points of virtual object?
Is it possible to map the coordinate points?
Old 02-28-2017, 12:16 AM
I'm not sure what you mean by collecting and mapping the coordinate points.
Old 04-16-2017, 06:46 AM
Hello Jeff
Microscribe is an hardware that provides the coordinate points (x,y,z) as .txt file, i need to collect the coordinate points and should give as input to virtual object.
Que 1
How to read .txt file in real time. my .txt file is frequently updated by the Microscribe hardware
is there any way to solve this??
Please give me some valuable suggestions...that would be wonderful.
Old 04-18-2017, 03:53 AM
You can use standard Python commands for reading text files in Vizard. In this case, you could try opening the file and then reading the last line written every frame or on some other time interval.
Local coordinate and global coordinate haohaoxuexi1 Vizard 2 07-24-2016 07:21 PM
Get object name from an X/Y screen coordinate williamchappell Vizard 2 08-08-2013 01:08 PM
How to make an object fixed in viewpoint coordinate system? Xianshi Xie Vizard 1 06-22-2009 11:31 AM
Pivot points for child objects in Vizard with 3ds Max Gladsomebeast Vizard 0 09-19-2006 11:21 AM
