Old 01-23-2017, 01:43 PM
Smile about maplotlib in Vizard
import matplotlib
matplotlib.use('agg')
import matplotlib.pyplot as plt
import time
import random
import viztask
import vizmatplot
#determine size of arrays (number of samples)
MAX_SIZE_OF_ARRAY = 5000
#create arrays
array_x, array_y = [],[]
#fill array with zeros
for i in range(0,MAX_SIZE_OF_ARRAY):
	array_x.append(0)
	array_y.append(0)
###---matplotlib codes---###
fig = plt.figure()	#instantiate pyplot figure
ax = fig.add_subplot(111)	#create axes
ax.axis([0,MAX_SIZE_OF_ARRAY,0,1])	#determine axis limits
line, = ax.plot(array_x,array_y)	#instantiate plot
matplot = vizmatplot.Show(fig)
matplot.showDrawRate(viz.ON)
def plotter():
	""" task that randomly creates y data while incrementing x data"""
	while True:
		#yield None
		for i in range (0,MAX_SIZE_OF_ARRAY):
			array_x[i] = (i)
			array_y[i] = (random.random())
			ax.axis([0, MAX_SIZE_OF_ARRAY, 0, 1])	#make sure the axis limits don't change
			line.set_data(array_x, array_y)	#set the data points
			yield None	#wait at least a frame before setting new data points
		#	yield viztask.waitTime(matplot.rate) #or wait draw rate length calculated in module
		for b in range(0,MAX_SIZE_OF_ARRAY):	#clear out the arrays
			array_x[b] = 0
			array_y[b] = 0
			line.set_data(array_x,array_y)	#clear graph by setting all data points to [0,0]
viztask.schedule( plotter() )
this code comes out an error of "RuntimeError: dictionary changed size during iteration", anyone know how to solve it?
the code was from matplotlib website in Vizard webpage.
Realistic Light and Shadows Using Vizard and 3DS Max jde Vizard 4 07-13-2012 11:58 AM
