Old 01-19-2017, 05:33 AM
Patrick Patrick is offline
Cooperation of things within the Virtual world
So i wrote a Program where i implemented a STL-Data (Basicly a Matlab created cuboid that should simulate a heating system).
Recently i started to use physics in my Program.
viz.setMultiSample(4)
vizconnect.go('vizconnect_hand_vive.py')
viz.phys.enable()
viz.collision(viz.ON)
ground = viz.addChild('ground_gray.osgb')
ground.collideplane()
Heizung = viz.addChild('heiz2.osgb')
Heizung.collideBox()
I set the ground as bottom and enabled the Heizung for physics via the CollideBox command.
The problem that i have now is that the cuboid (who is higher than he is wide) just drops over to the front. What i want it to do tho is to fix that cuboid at the bottom so it basicly simulates an imobile machine. So the question is can i attach that Child to the ground level and make it kinda "heavy" as if a massive metal block would stand there.
And on top of that i wanted to figure out a way to attach smaller boxes to it. Basicly if i take a generated box and put it at a certain point of the Big block it gets attached to that point.
box1 = vizshape.addCube(size=0.2, pos=[0,1.45,5.4],alpha=1)
box1.collideBox()
So if i take that Box and put it at a certain point (that i defined before) somewhere on the side of my "Heizung" it gets attached to that automatically and stays at that point? But if i grab it again i want to be able to remove it again aswell.
Thanks in Advance
Old 01-23-2017, 12:45 PM
Reducing the bounce of the box may help prevent it from falling over after it's dropped. Here's an example:
Press spacebar to enable physics and drop the box
import vizshape
import vizinfo
vizinfo.InfoPanel()
viz.clearcolor(viz.SLATE)
ground = viz.add('ground.osgb')
ground.collidePlane()
box = vizshape.addBox(size=(.4,2,0.4),pos=[0,20,8])
shape = box.collideBox()
shape.setBounce(0.01)
vizact.onkeydown(' ',viz.phys.enable)
If you want objects to snap into place after colliding try handling the collision event and then animate or directly place the object where you want it to go.
Old 01-24-2017, 04:15 AM
The problem is not that the boxes drop but the osgb i imported
The Heizung Attribute is a STL data i implemented and edited it with the inspector. The boxes i implemented work perfectly fine they drop and lay staticly on the ground after they fell but the heiz1.osgb (a picture of it is attached) just drops over and i dont know why it does that in first place when i enable the phisycs
Old 02-02-2017, 03:37 AM
Hey,
just a quick question to the topic above again.
I think i found the problem. Like the Screenshot shows, the center of gravity is at the down left front corner of the object. so i think the physics apply at that point and thats why the object drops so weird on the ground.
I found sth about the pivot point in the documentary which defines the the turn axe of the object. Does that point also determines where the physics apply?
So i just had to move the point in the screenshot to the center of the object and i guess the problem would be solved. I found the solution in the documentary but all these functions are not shown in my instructor, so my question is how do i move that center of gravity?
Sorry to bother you so much but thanks for the help in advance
Old 02-02-2017, 05:30 AM
Forgot to attach the Screenshot
here we go
Old 02-02-2017, 05:12 PM
The node.setCenter command will change the object's center of rotation. I'm not sure but it might also help in this case.
@jeff
Augmented Reality: virtual world not overlapping real world correctly Vaquero Vizard 7 04-15-2016 02:14 AM
Making Virtual World Using Video Recording Hitesh Vizard 2 06-22-2015 10:03 AM
Showing another program in a virtual world Frank Verberne Vizard 3 01-16-2013 11:26 AM
why is time faster in my virtual world? billjarrold Vizard 1 11-24-2009 06:33 PM
Vizard as a social virtual world engine Gerard Vizard 3 02-14-2008 03:22 PM
