Old 01-03-2017, 11:49 PM
imnotamember imnotamember is offline
Problem Rotating object linked to viz.HEAD
Hi all,
I'm trying to make a compass to guide a person to their next location in a room and having the hardest time doing it. I've been creating an arrow that sits just before the main view and every second the .lookAt() method is run to turn the arrow towards the next spot. The problem I'm currently stuck with is that the arrow doesn't turn independently relative to the main view's position.
Here is code using the gallery sample to highlight how the arrow is working:
import vizshape
viz.setMultiSample(4)
viz.fov(60)
viz.MainView.move([0,0,-1])
#Create skylight
sky_light = viz.addLight(euler=(0,90,0))
sky_light.position(0,0,-1,0)
sky_light.color(viz.WHITE)
sky_light.ambient([0.9,0.9,1])
#Add the gallery model
gallery = viz.addChild('gallery.osgb')
#Add audio
music = viz.addAudio('bach_air.mid',loop=1)
music.loop(viz.ON)
music.play()
#Add an avatar
avatar = viz.addAvatar('vcc_male2.cfg',pos=[0,0,1])
avatar.state(1)
#Create static drop shadow to avatar
shadow_texture = viz.addTexture('shadow.png')
shadow = vizshape.addQuad(parent=avatar,axis=vizshape.AXIS_Y)
shadow.texture(shadow_texture)
shadow.zoffset()
#Move avatar around the room with a sequence of walk, turn, and wait actions
#Create action to wait 5-10 seconds
RandomWait = vizact.waittime(vizact.randfloat(5,10))
#A list of painting locations
avatarMove = [[-3.7,2.2,300],[-3.7,6.5,270],[0,8,0],[3.7,6.5,90],[3.7,2.6,90],[3.7,1,130]]
actions = []
for loc in avatarMove:
	#Add an action to walk to the next painting, turn towards it, and wait a few seconds
	actions.append(vizact.method.playsound('footsteps.wav',viz.LOOP))
	actions.append(vizact.walkTo([loc[0],0,loc[1]],turnSpeed=250.0))
	actions.append(vizact.method.playsound('footsteps.wav',viz.STOP))
	actions.append(vizact.turn(loc[2],250.0))
	actions.append(RandomWait)
#Repeat the sequence of actions forever
avatar.addAction(vizact.sequence(actions,viz.FOREVER))
arrow = viz.addChild('marker.wrl', parent=viz.HEAD)
arrow.alpha(.8)
arrow.setScale([.25]*3)
arrow.setPosition(0,0,.5)
def updateArrow():
	arrow.lookAt(avatar.getPosition(mode=viz.ABS_GLOBAL), mode=viz.ABS_GLOBAL)
vizact.ontimer(0,updateArrow)
As you'll see, regardless of where you (viz.HEAD) move or turn in the gallery, the arrow responds only as though it were permanently located at the spot it first started. I want it to make real-time updates on where the guy and look towards him regardless of where the viz.MainView is located/turned towards. Thank you in advance for any ideas you might have.
compass, coordinate system, mainview, orientation
Problem with object position Ryvan Vizard 2 01-22-2015 02:01 PM
Object + InteriaCube + Viewport problem Gekitatsu Vizard 1 02-22-2012 11:55 AM
Freeform view on an animated object problem jaylocco Vizard 2 06-08-2009 09:09 PM
Object rotating around world axis, not own axis tacbob Vizard 1 02-15-2007 10:12 AM
