Old 12-12-2016, 01:56 PM
handerson11 handerson11 is offline
Populating Object with Spheres
Similar to:
http://forum.worldviz.com/showthread...t=physics+ring
Is there a method to populate more complex shapes with spheres?
I can't use a mesh on my objects as I need them to react to forces and gravity.
Old 12-13-2016, 03:11 AM
rajnishv rajnishv is offline
Hi handerson11,
You may use the 'vizshape' module to create 3D Spheres
Also pls visit the link:
http://docs.worldviz.com/vizard/inde...shape%7C_____9
Or
You may search 'vinzinfo' in Vizard IDE Documentation Section.
Thank You!!!
Getting an object location chris2307 Vizard 4 01-10-2017 04:43 AM
Rotate object around mainView? performlabrit Vizard 3 12-19-2013 06:31 AM
