Old 12-08-2016, 04:19 AM
tianmoran tianmoran is offline
Unhappy Recording videos of the screen
Currently, I would like to use vizard to generate a piece of movie. Yet there are two problems:
1, The quality of the picture is so bad;
2, I want to use viz.setOption('viz.AVIRecorder.fps','10') to nake some change, but error said:
AttributeError: 'module' object has no attribute 'AVIRecorder'
Could anyone help me? Thanks a lot!
Old 12-08-2016, 02:45 PM
1) I'm not sure why there would be issues with the quality. You could try a 3rd party recorder to see if that works better.
2) Do you get the same error running the following code?
viz.add('piazza.osgb')
vizact.onkeydown('b', viz.window.startRecording, 'test.avi' )
vizact.onkeydown('e', viz.window.stopRecording )
Old 01-25-2017, 10:55 AM
hi Jeff, this problem has been settled. Thanks!
record movie
Screen Size and Scaling javadi Vizard 2 04-02-2013 05:56 PM
Attach a TexQuad to pit.osgb screen Ducky Vizard 1 01-17-2013 02:57 PM
Recording videos nlucena Vizard 2 08-23-2012 01:50 AM
recording screen in vizard when embedded in wxpython Renato Lima Vizard 0 11-21-2011 01:10 PM
position of html-file on screen active_world Vizard 1 05-16-2008 07:24 PM
