Old 12-05-2016, 09:46 AM
handerson11 handerson11 is offline
Collision complex shapes
I am making a realistic assembly process with complex objects and realistic physics. I am currently populating the objects with spheres for collision but it is proving problematic and very time consuming.
Is there a simpler way to detect collision whilst having realistic physics being applied and allowing for grabber tool interaction?
Here is an example of a simple disc:
#Discs
#Disc1
Disc1=viz.addChild('Disc VR Models\Bottom Disc.wrl', euler=(0,90,0), color=viz.GREEN, alpha=1)
#Disc1.collideBox(friction=.001)
RADIUS = 0.075
TUBE_RADIUS = 0.02
for deg in range(0,360,10):
	x = math.sin(viz.radians(deg)) * RADIUS
	z = math.cos(viz.radians(deg)) * RADIUS
	Disc1.collideSphere(radius=TUBE_RADIUS,pos=(x,z,0))
Disc1.enable(viz.COLLIDE_NOTIFY)
Disc1.crashSound = viz.add('sounds/crashQuiet.wav')
Disc1.setPosition(0,1,1)
Harry Anderson
Old 12-05-2016, 01:24 PM
If you don't need the complex model to be affected by forces then you could use a collide mesh to detect when other objects collide with it.
Old 12-06-2016, 01:31 AM
I need it to be acted on by gravity.
Is there any way to program the mesh to be acted on by gravity?
Or is there another way to make the parts seem like gravity is acting on them?
Old 12-06-2016, 07:18 AM
It needs to be acted on by gravity and not intersect other objects when being grabbed.
Old 12-06-2016, 10:13 AM
The collide mesh will not react to gravity. You could use the vizact.fall command to create a falling animation.
Old 12-08-2016, 09:06 AM
Hi Jeff thanks again,
I was trying to get the objects to fall realistically which is something that is key in my program, also I need objects to fall on top of each other as they would in real life.
.bsp->.obj->.osgt map Collision Problem/Resources for free maps? plogic Vizard 0 10-24-2014 07:59 AM
Physics: Ball Bounces Unexpectly Based Upon Size + Ring Collision Shape mhead10 Vizard 3 11-02-2012 01:44 PM
Collision Exception jassel41 Vizard 2 11-09-2010 05:08 PM
Collision and avatar animation shahramy Vizard 2 10-26-2010 11:47 PM
